Posted Config Have Only Two Small SIP Issues CME 4.1
I really got as far as I could with all the research I did, initially not knowing anything about integrating two internet based SIP phone numbers from Flowroute.com into my 1760 CME 4.1 I am only left with two issues. When I call a POTS line from my CME the call is perfect. Am I missin something from this config?
When I call my CME FROM a POTS line, the CME phone rings, you answer it but hear nothing either way. No voice either way.
When I call my CME FROM a POTS line, don't answer the CME and hang up the POTS line, the CME phone does NOT stop ringing.
Here is my config. Any suggestions?
version 12.4
hostname Call_Manager-B
boot-start-marker
boot-end-marker
no logging console
enable secret 5 $1$AL1E$eyIJx.a68KVuC1N762Zre/
no aaa new-model
clock timezone EST -4
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.16.3.1 172.16.3.9
ip dhcp excluded-address 172.16.4.1 172.16.4.9
ip dhcp pool DATA_SCOPE
network 172.16.4.0 255.255.255.0
default-router 172.16.4.1
ip dhcp pool VOICE_SCOPE
network 172.16.3.0 255.255.255.0
default-router 172.16.3.1
option 150 ip 172.16.3.1
no ip domain lookup
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip refer
sip
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
archive
log config
hidekeys
translation-rule 1
Rule 0 ^91 1
interface Ethernet0/0
description Ethernet To Internet Through Linksys
ip address 192.168.6.250 255.255.255.0
full-duplex
interface FastEthernet0/0
no ip address
speed auto
interface FastEthernet0/0.10
description Router Interface For Voice Vlan
encapsulation dot1Q 10
ip address 172.16.3.1 255.255.255.0
ip helper-address 172.16.4.5
interface FastEthernet0/0.50
description Router interface For Data Vlan
encapsulation dot1Q 50
ip address 172.16.4.1 255.255.255.0
interface Ethernet1/0
description Telnet Management
ip address 192.168.2.110 255.255.255.0
half-duplex
ntp broadcast client
ip forward-protocol nd
ip route 216.115.0.0 255.255.0.0 192.168.6.1
ip http server
no ip http secure-server
ip http path flash:/gui
tftp-server flash:/phone/7912/CP7912080001SCCP051117A.sbin alias CP7912080001SCCP051117A.sbin
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/gui/speeddial.xml alias speeddial.xml
control-plane
dial-peer voice 1 voip
destination-pattern 91..........
translate-outgoing called 1
voice-class codec 1
session protocol sipv2
session target ipv4:216.115.69.144
dtmf-relay sip-notify
num-exp 2001 17275652954
num-exp 2002 18134982327
sip-ua
authentication username xxxxxxxx password 7 xxxxxxxxxxxx
no remote-party-id
registrar ipv4:216.115.69.144 expires 3600
telephony-service
load 7912 CP7912080001SCCP051117A
max-ephones 4
max-dn 12
ip source-address 172.16.3.1 port 2000
max-conferences 4 gain -6
moh music-on-hold.au
multicast moh 239.23.4.10 port 2000
transfer-system full-consult
transfer-pattern 200.
secondary-dialtone 9
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 1
number 17275652954
label 727-565-2954
name PHONE-3
ephone-dn 2
number 18134982327
label 813-498-2327
name PHONE-4
ephone 1
mac-address 0015.C617.CE82
button 1:1
ephone 2
mac-address 0015.63FF.5284
button 1:2
One Way - No Way Audio more often than not is caused by IP Routing issues. There is no details mentioned about the call flow so would be able to provide much of an input, but one thing which you might want to start checking with is what is the route between the IP Phone and the last IP hop before the call is sent to POTS (TDM) network.
If this router were literally plugged into the network and one phone hanging off of the router, I would say your situation is impossible. But, given I've had a 1760 that only comes with one ethernet port and used a SIP ITSP like you are now, I know there are external factors involved. For example, take a look at the device servicing your internet (NAT device). Is there any Stateful Packet Inspection (SPI firewall) enabled for your 1760? A lot of the newer SOHO routers have two modes of firewall (regular and SPI). You might even have to put the 1760 in the DMZ port just to rule it out. Also, if your NAT router has any type of SIP ALG enabled, turn it off. SIP ALG inserts packets into the SIP traffic that will break phone calls. Lastly, if your phone is hanging off of anything after the 1760 that does any type of routing, make sure the IP routing from the NAT router all the way to the phone and backwards is symmetric. Your 1760 isn't incredibly complex so I'm a firm believer this is something external to the 1760. Once you have two way audio, then you can troubleshoot issues such as MOH, supplementary services, codec negotiation, etc.
I will look into the Linksys part of this very closely. When I make a call form the 1760 to a POTS line, I can hear audio both ways (codecs are working), I can stream hold music to the POTS phone and I can trasfer the call from one CME extension to another. Caller ID works in both dierections too. It's the reverse that has the problem. When I make a call from POTS line to CME, it rings the proper CME phone, displays caller ID but no audio in either direction once you answer. If you don't answer the CME phone and hang up the POTS phone, the CME phone doesn't stop ringing.
I fixed it. Everything works perfect now. Instead of a default route of ip route 216.115.0.0 255.255.0.0 192.168.6.1, I used ip route 0.0.0.0 0.0.0.0 192.168.6.1  I looked at the CCSIP debug messages and saw that ip's were failing for some SIP communications. I thought that just because the flowroute ip address was 216.115.69.144 I could use the 216.215.0.0 in my static route. Obviously not.
Glad everything worked out.
Did this solution also stop your CME phone ringing when you call your CME from POTS and hang up?
After further investigation I was not getting the proper SIP BYE message for the Cisco phone to stop ringing when the POTS line hung up. It was also determined that I wasn't quite registering properly with my SIP provider (Port number among other things I suppose). After researching many configs I put this together and the SIP BYE messages were good and my registration was better and the phone stopped ringing. There isn't just one config out there that works perfectly. I had to experiment and pull statements from one config and another and put this together (and of course looking up what the statements actually did).. A good learning process..
voice service voip
redirect ip2ip
sip
registrar server expires max 160 min 160
localhost dns:sip.flowroute.com:5060
dial-peer voice 2 voip
destination-pattern .T
redirect ip2ip
voice-class codec 1
voice-class sip localhost dns:sip.flowroute.com
voice-class sip dtmf-relay force rtp-nte
session target dns:sip.flowroute.com
incoming called-number .%
dtmf-relay rtp-nte
no vad
sip-ua
credentials username xxxxxxxx password 121C2F251F0C2D5D0D2D000000 realm sip.flowroute.com
authentication username xxxxxxxx password 7 121C2F251F0C2D5D0D2D000000
nat symmetric check-media-src
no remote-party-id
retry invite 2
retry register 10
timers connect 100
registrar ipv4:216.115.69.144 expires 60
connection-reuse
host-registrar
ephone-dn 1
number 17275652954 secondary 2001 no-reg both
ephone-dn 2
number 18134982327 secondary 2002 no-reg both
1305
