Potential T1 clocking prolems?
Our customer purchased a 2851 but instead of the vwic2-mft's they bought the vwic-mft's (first generation). Will there potentially be clocking issues for below setup?
vwic-2mft - 1st port used for incoming PRI, 2nd configured as PRI and connected back to back to NM-1CE1T1-PRI (this setup is to get modem calls into NM-1CE1T1-PRI and onto PVDM2-12DM)
second vwic-2mft - port one and port two will be for frame-relay connections.
vwic-1mft (T1 connection up to MPLS network).
thanks
Hall of Fame Super Gold
Re: Potential T1 clocking prolems?
Hi, you should have no issues. Each wic can be off independent clocks. Don't forget to configure network-clock-participate.
Also, you can now terminate the modem calls directly using the vwic, it's in some new IOS, I can't find the release notes now, but I will eventually.
Woops, the correct info is that they added yet another T1/E1 WIC card that works with the digital modems, here it is:
http://cisco.com/en/US/products/ps6441/products_feature_guide09186a00806b941f.html#wp1088585
118
