06-14-2010 12:55 PM - edited 03-15-2019 11:14 PM
Good afternoon,
The site in question has 10 digit local dialing but management wants the users at the site to only dial 7 digits. I have put these instructions in the router config and it is not working. Any help will be greatly appreciated as I continue my learning journey.
dial-peer voice 300 pots
description Local Calling 7 Digit
destination-pattern 9[2-9]......$
port 0/0/0:23
prefix 904
forward-digits 10
RI
Solved! Go to Solution.
06-15-2010 05:00 AM
Forward digits applies to the digits matched by the destinatio-pattern string. I believe it take effect before the prefix is applied... so forward-digits 10 would result in the 7 digits plus 9 prefix being sent out, then prefixed with 904.
9049.......
As pointed out earlier, if you run a debug isdn q931 it becomes quite obvious what is going on...
Please rate helpful posts..
06-15-2010 03:27 PM
06-14-2010 01:55 PM
Got busy tone or else when dial '9'+7digits? what is your 'show dial-p voi sum' result?
06-14-2010 01:55 PM
What's the exact behavior you're getting?
What are you dialing?
What is PSTN expecting?
You could gather a debug voip ccapi inout to see exactly what you're sending to the PSTN.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
06-14-2010 03:00 PM
try to make your dial-peer as bellow
port 0/0/0:23
prefix 904
when the user dial 9 and followed by 7 digits 9[2-9]......$ the 9 will be removed and 904 will be added to the number resulting in 10 digits
also debug i sdn q931 to see what digits you sending to the teleco
good luck
06-15-2010 04:43 AM
Thank you for your answer. Don't I need to add a forward-digits 10 to this. I can't do a forward-digits all because of the leading 9 and because of the preceding 9 to get dial tone I can't use default can I?
RI
06-15-2010 05:00 AM
9049.......
06-15-2010 09:05 AM
That is exactly what happened. I did the debug on an 7 digit outbound call and it showed 9049XXXXXXX where the X's are the local number. So how do I get rid of tthe middle 9 (the dial 9 for outside line)? I have tried to put in the following:
voice translation-rule 1
rule 1 /^9049/ /904/
translate-outgoing called 1
I still get the same results a busy with the 9049 then the 7 digit number.
RI
06-15-2010 03:11 PM
just do it as i mentioned above
remove the forward digit all
this way the explicit matching in ur pots dialpeer will be removed which is the 9 and then the 904 will be added to the dialed number
just do it and then debug to see the diffrence
good luck
if helpful Rate
06-15-2010 03:15 PM
Should I set the forward digits back to default?
RI
06-15-2010 03:27 PM
just do under the dialpeer
no forward-digits all
or
no forward-digits
06-15-2010 03:37 PM
As I understand it you cannot give a no command here. The command to set it back to default is default forward-digits.
RI
06-16-2010 04:54 AM
I put the default forward-digits in the dial peer and it works now. Thanks to everyone who tried to help!!!
RI
