POTS Dial-Peer Question
Good afternoon,
     The site in question has 10 digit local dialing but management wants the users at the site to only dial 7 digits. I have put these instructions in the router config and it is not working. Any help will be greatly appreciated as I continue my learning journey.
dial-peer voice 300 pots
description Local Calling 7 Digit
destination-pattern 9[2-9]......$
port 0/0/0:23
prefix 904
forward-digits 10
RI
2 ACCEPTED SOLUTIONS
Super Bronze
Re: POTS Dial-Peer Question
Forward digits applies to the digits matched by the destinatio-pattern string. I believe it take effect before the prefix is applied... so forward-digits 10 would result in the 7 digits plus 9 prefix being sent out, then prefixed with 904.
9049.......
As pointed out earlier, if you run a debug isdn q931 it becomes quite obvious what is going on...
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
just do under the dialpeer
no forward-digits all
or
no forward-digits
Got busy tone or else when dial '9'+7digits? what is your 'show dial-p voi sum' result?
What's the exact behavior you're getting?
What are you dialing?
What is PSTN expecting?
You could gather a debug voip ccapi inout to see exactly what you're sending to the PSTN.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
try to make your dial-peer as bellow
port 0/0/0:23
prefix 904
when the user dial 9 and followed by 7 digits 9[2-9]......$ the 9 will be removed and 904 will be added to the number resulting in 10 digits
also debug  i sdn q931 to see what digits you sending to the teleco
good luck
Thank you for your answer. Don't I need to add a forward-digits 10 to this. I can't do a forward-digits all because of the leading 9 and because of the preceding 9 to get dial tone I can't use default can I?
RI
Super Bronze
9049.......
That is exactly what happened. I did the debug on an 7 digit outbound call and it showed 9049XXXXXXX where the X's are the local number. So how do I get rid of tthe middle 9 (the dial 9 for outside line)? I have tried to put in the following:
voice translation-rule 1
     rule 1 /^9049/ /904/
      translate-outgoing called 1
I still get the same results a busy with the 9049 then the 7 digit number.
RI
just do it as i mentioned above
remove the forward digit all
this way the explicit matching in ur pots dialpeer will be removed which is the 9 and then the 904 will be added to the dialed number
just do it and then debug to see the diffrence
good luck
if helpful Rate
Should I set the forward digits back to default?
RI
or
no forward-digits
As I understand it you cannot give a no command here. The command to set it back to default is default forward-digits.
RI
I put the default forward-digits in the dial peer and it works now. Thanks to everyone who tried to help!!!
RI
381
