POTS SCCP SRST TRYING TO REGISTER
Oswaldo Torres
Hello
I was setting up CUBE with SIP Trunk to the PSTN. This router is also set up for SCCP SRST, we have some dial-peer pots configured.
After configuring this dial-peers we saw messages trying to register.
To stop this we configure the command "no sip-register"
dial-peer voice 7000 pots
destination-pattern ........
port 0/2/0
no sip-register
But I can't find, how to stop register message in a e-phone dial-peer pots when this router is in SRST mode ?
CUBE_GOLD#show sip-ua register status
Line                             peer       expires(sec) registered P-Associ-URI
67952                            20001      95           no         <--------------------------------!!!!!!!!
8182862940                       -1         49           yes
CUBE_GOLD#
CUBE_GOLD#sh dial-peer voice sum
dial-peer hunt 0
             AD                                    PRE PASS                OUT
TAG    TYPE  MIN  OPER PREFIX    DEST-PATTERN      FER THRU SESS-TARGET    STAT PORT    KEEPALIVE
5001   voip  up   up                                0  syst sip-server
5002   voip  up   up             *320T              0  syst sip-server
5003   voip  up   up                                0  syst sip-server
5004   voip  up   up             294.               0  syst ipv4:172.31.1.254
20001  pots  up   up             67952$             1                           50/0/1      <--------------------------------!!!!!!!!
20002  pots  up   down                              1                           50/0/2
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 172.31.3.1 port 2000
max-ephones 10
max-dn 20 dual-line preference 1
system message primary MODO SUPERVIVENCIA
system message secondary MODO SUPERVIVENCIA
keepalive 20
boris.kudr
Hi Oswaldo,
try adding "no register e164" under pots dial-peer and "max-dn 20 dual-line preference 1 no-reg" under SRST section.
Cheers,
Boris
_____ Please rate helpful posts Пожалуйста оценивайте полезные сообщения
boris.kudr
Hi Oswaldo,
Cheers,
Boris
Tks. We add the "no-reg" command.
8182862940                       -1         21           yes
CUBE_GOLD#
CUBE_GOLD#sh run | beg call-manager-fallback
max-ephones 10
keepalive 20
