Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
POTS SCCP SRST TRYING TO REGISTER
Hello
I was setting up CUBE with SIP Trunk to the PSTN. This router is also set up for SCCP SRST, we have some dial-peer pots configured.
After configuring this dial-peers we saw messages trying to register.
To stop this we configure the command "no sip-register"
dial-peer voice 7000 pots
destination-pattern ........
port 0/2/0
no sip-register
But I can't find, how to stop register message in a e-phone dial-peer pots when this router is in SRST mode ?
CUBE_GOLD#show sip-ua register status
Line                             peer       expires(sec) registered P-Associ-URI
67952                            20001      95           no         <--------------------------------!!!!!!!!
8182862940                       -1         49           yes
CUBE_GOLD#
CUBE_GOLD#sh dial-peer voice sum
dial-peer hunt 0
             AD                                    PRE PASS                OUT
TAG    TYPE  MIN  OPER PREFIX    DEST-PATTERN      FER THRU SESS-TARGET    STAT PORT    KEEPALIVE
5001   voip  up   up                                0  syst sip-server
5002   voip  up   up             *320T              0  syst sip-server
5003   voip  up   up                                0  syst sip-server
5004   voip  up   up             294.               0  syst ipv4:172.31.1.254
20001  pots  up   up             67952$             1                           50/0/1      <--------------------------------!!!!!!!!
20002  pots  up   down                              1                           50/0/2
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 172.31.3.1 port 2000
max-ephones 10
max-dn 20 dual-line preference 1
system message primary MODO SUPERVIVENCIA
system message secondary MODO SUPERVIVENCIA
keepalive 20
1 ACCEPTED SOLUTION
Bronze
Hi Oswaldo,
try adding "no register e164" under pots dial-peer and "max-dn 20 dual-line preference 1 no-reg" under SRST section.
Cheers,
Boris
_____ Please rate helpful posts Пожалуйста оценивайте полезные сообщения
Bronze
Hi Oswaldo,
Cheers,
Boris
Tks. We add the "no-reg" command.
8182862940                       -1         21           yes
CUBE_GOLD#
CUBE_GOLD#sh run | beg call-manager-fallback
max-ephones 10
keepalive 20
280
