Community Member
pound key to bypass T302 timer problem
Hi All,
I am using CUCM 7.1. When I dial international number then press pound key to bypass T302 timer, I receive busy tone. But when I wait for 15 sec, the call is successful. is there any service parameter in CUCM to allow dialing # key to make a call immediately?
thanks
Alex
1 ACCEPTED SOLUTION
Re: pound key to bypass T302 timer problem
U have to create another route pattern with 9.!#
Hall of Fame Super Gold
Why don't you change interdigit timeout to 3 or 4 seconds like most people do ?
Community Member
thanks for your response. But I need to use #, since most people get used to it.
I think a good installation has both reasonable timeout, and pound termination.
Then, some countries use fixed lenght numbers, that you can configure if dialed frequently.
Bronze
Hi, just a suggestion, do you have a route pattern with the # symbol at the end, for example: 9.!#
hth
David
494
