power commands not available in 2811 with 9esw module
I have a POE version of the 2811 with an HWIC-D-9ESW module. I cannot do a "show power" from global config and I cannot do "power inline auto" from interface config mode. The command is not available at all. My image is an Voice/CME image v 12.4(9). Any ideas?
Diego
  • IP Telephony
Hall of Fame Super Gold
Re: power commands not available in 2811 with 9esw module
Hi, to enable poe on the hwic you also need a power module on the card, and the poe power supply.
Both are optional items to purchase. You can check what you have in the router with "show diag".
Please rate post if it helps!
The hwic part makes sense since this is a replacement hwic which they probably sent without the power module. I still have the old one that I can remove that module from.
As far as the router chassis goes the old one was an AC-IP POE model and this replacement should also be an AC-IP according to the packing slip. How can I verify this? I tried show diag and show environment and neither of these two commands shows the poe power supply. Here is the output:
C2811 Motherboard with 2FE and integrated VPN Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
PCB Serial Number : *********
Hardware Revision : 1.0
Top Assy. Part Number : 800-26920-04
Board Revision : A0
Deviation Number : 77369
Fab Version : 04
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 87
Hardware date code : 20071111
Chassis Serial Number : *********
Chassis MAC Address : 001e.7a6e.0e78
MAC Address block size : 24
CLEI Code : COM7R00ARA
Product (FRU) Number : CISCO2811
Part Number : 73-10258-05
Version Identifier : V05
Main Power Supply is AC with -48V
-48V supply status: OK
-48V relay status: ISOLATED
Fan 1 OK
Fan 2 OK
Fan 3 OK
System Temperature: 26 Celsius (normal)
Environmental information last updated 00:00:28 ago
Diego
Seems to me the AC-IP is there so you're only missing the daughtercard.
Before you go crazy trying to set PCs chained to phones off the hwic, remember to configure switchport as trunk, then congiure voice vlan as usual.
Access mode does not work like on true switches.
Thanks for the appreciation and good luck!
Thank you for your quick and insightful help.
Diego
772
