Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Pre-recorded alert messages
We are currently running CM 6.1 and we want to make some changes to our analog paging. We want to add a couple of pre-recorded messages to play over the paging speakers, 1 in case of fire and the other for tornado. Is this possible with this version of CM? How do I go about doing this if it is possible?
Only possible option I can see for this is that if you're reaching the paging system dialing a DN to record that as MOH, other than that, there's no other option to record anything in CUCM.
You dial the paging DN and then put him on hold.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
If we were to record the message as MOH, how would we choose which message we wanted to play when we put it on hold? And, then anyone that gets put on hold would hear this alert, wouldn't they?
By choosing the MOH source for that DN to the message, obviously you can only select one message, that's the caveat.
java
java
228
