preference in dial-peer voice
I've a trouble with 2 call-manager in cluster that i don't know were to begin to fix it.
When a call from ISDN goes to the gateway, I've 2 dial-peer voice that forward that call to the callmanager; I used, as always, the preference 1 and preference 2 to set the target ccm1 and ccm2.
Disconnecting one ccm from the network I've seen:
A) if the callmanager disconnected is the one with preference 2, there are no problem.
B) if the callmanager I disconnect is the one associated with preference 1, the call is delayed of several seconds ( more than 15 ).
It seems like the dial-peer with the best preference wait a long timeout before to use the other.
Anyone had similar troubles ?
Luigi
PS: from "debug voice dial-peer detail" i see the match for both dial-peer, then the calls "wait" 10-15 seconds, then goes to the preference 2 ccm.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: preference in dial-peer voice
Hi Luigi,
I think you haven't set the H225 timeout correctly:
voice class h323 1
h225 timeout tcp establish 3
See the full document:
http://cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080094852.shtml
Hope this helps, please rate useful posts using the scrollbox below!
Hi Luigi,
voice class h323 1
Many thanks,
I found the doc after i sent that request on the forum; full 5 points for You.
Ragards
Luigi
PS: Bevilacqua... are You from Genoa ?
Thank you Luigi for the nice rating.
I'm from Rome.
Good luck!
Prego,
io sono di Genova, anche se lavoro a Milano
ciao
Luigi
124
