prefix a number on fxs port and trunk group
Hi all,
PBXA FXO--->R1-FXS-----IP------R2FXS----PBXB FX
we used router fxs connection PBX's fxo.
When PBXA user press 6XXX( PBXB ), PBXA will auto jump to the special line connect to R1 FXS,and user heard dialtone,and Router only recieved XXX.
We want PBXA user dialed 6XXX,and PBXA sending 6XXX to router.
It looks like 6 is just a line choice number ,not a dialed number.
I tried translation-rule or translation-profile , but no helpful.
So how to prefix a 6 on FXS port ?
And, i heard a trunk group can connect PBXA to PBXB, and i cant find any configuration example for fxs to fxs.
When i configured
voice-port 0/0/0
connection trunk 6000
the voice-port become trunk mode,and flapping un and down,and user always heaed busy tone when selected special line.
VIP Super Bronze
It looks like this:
voice translation-rule 1
  rule 1 /^...$/ /6\0/
voice translation-profile INCOMING-PBXA
  translate called 1
voice-port 0/0/0
translation-profile incoming INCOMING-PBXA
Trunk groups are used to group multiple voice-ports into a single outbound dial-peer. For example, if you had four interfaces connecting to PBXB you could put them in a trunk group and then write a single dial-peer pointing to that trunk-group.
http://www.networkworld.com/community/node/41680
Please remember to rate helpful responses and identify helpful or correct answers.
HI,Jonathan,
I already used the following configuration to translate the called number, and it does not worked.
  rule 1 // /6/
  translate called 1
voice-port 0/0/0
and i used "test voice translation-rule " to proved it.
It looks almost like your configuration, i'll try it tomorrow and tell you about the result.
Thank u very much.
Hi Jonathan,
It dose not worked.
FXS port was in dial mode when user press 6,no called number sended.
483
