Prefix FXO line
I Have a FXO card and I want that the extension 100 can take this line.
How to create a prefix to take this line, for example I want to dial 0 to take this line? And how to program a key on the IP Phone to take this line?
voice-port 0/3/0
connection plar 100
1 ACCEPTED SOLUTION
Re: Prefix FXO line
ok then forward all the dialed digits.
for example for loca calls you will dial 0 then the 7 digits number as below:
dial-peer voice 10 pots
destination-patter 0[2-9]......
port 0/3/0
forward digits 7
try that
Hall of Fame Super Silver
Re: Prefix FXO line
You need to create a dial peer in order to control outboud calls, i.e.
dial-peer voice 1 pots
destination-pattern 0
port 0/3/0
forward-digits 1
connection plar controls inboud destination, so if a call arrives on this port from the connected device (PSTN) it will be forwarded to extension 100.
HTH,
Chris
Re: Prefix FXO line
Now when I dial the number 0, the call try to take the port 0/3/3 and after the port 0/3/2 and after again the port 0/3/1 before to arrive at the correct line at 0/3/0.
The call don't take directly the port 0/3/0, why?
Re: Prefix FXO line
plz post your full configuration, you should have something conflicting the mentioned dial-peer.
thx
Re: Prefix FXO line
See my conf.
Now I have an another problem when I try to take my line on port 0/3/0 I can see an activity on this port (green led) but no tone.
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
h323
sip
registrar server expires max 3600 min 3600
voice class codec 1
codec preference 1 g711ulaw
voice translation-rule 9
rule 1 /^911$/ /911/
rule 2 /^0\(.*\)/ /\1/
controller E1 0/0/0
controller E1 0/0/1
class-map match-all L3-to-L2_VoIP-Cntrl
match ip dscp af31
class-map match-all L3-to-L2_VoIP-RTP
match ip dscp ef
class-map match-all SIP
match protocol sip
class-map match-all RTP
match protocol rtp
policy-map EthOut
class RTP
policy-map output-L3-to-L2
class L3-to-L2_VoIP-RTP
set cos 5
class L3-to-L2_VoIP-Cntrl
set cos 3
interface Loopback0
ip address 10.1.10.2 255.255.255.0
interface GigabitEthernet0/0
description $FW_OUTSIDE$
ip address dhcp
ip access-group 101 in
ip nat outside
shutdown
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
ip address 10.10.10.1 255.255.255.0
ip access-group 100 in
no ip mroute-cache
duplex auto
speed auto
media-type rj45
h323-gateway voip bind srcaddr 10.10.10.1
interface Integrated-Service-Engine3/0
no ip address
no keepalive
ip http server
ip http authentication local
ip http secure-server
ip http path flash
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny ip 10.0.0.0 0.0.0.255 any
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 deny ip 20.0.0.0 0.0.0.255 any
access-list 101 permit udp host 205.152.0.20 any
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
access-list 101 deny ip 10.0.0.0 0.255.255.255 any
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip host 0.0.0.0 any
access-list 101 deny ip any any log
tftp-server flash:P00307020200.sbn
tftp-server flash:P00307020200.bin
tftp-server flash:TERM70.7-0-1-0s.LOADS
tftp-server flash:TERM70.DEFAULT.loads
tftp-server flash:TERM71.DEFAULT.loads
tftp-server flash:cnu70.2-7-4-134.sbn
tftp-server flash:Jar70.2-9-0-117.sbn
tftp-server flash:CVM70.2-0-0-112.sbn
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
connection plar opx 601
caller-id enable
voice-port 0/2/1
caller-id enable
voice-port 0/2/2
caller-id enable
voice-port 0/2/3
caller-id enable
voice-port 0/3/0
connection plar 100
caller-id enable
voice-port 0/3/1
caller-id enable
voice-port 0/3/2
caller-id enable
voice-port 0/3/3
caller-id enable
voice-port 4/0/0
voice-port 4/0/1
voice-port 4/0/2
voice-port 4/0/3
voice-port 4/0/4
voice-port 4/0/5
voice-port 4/0/6
voice-port 4/0/7
Re: Prefix FXO line
dial-peer cor custom
name internal
name local
name domestic
name international
name 900
name 976
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-domestic
member domestic
dial-peer cor list call-international
member international
dial-peer cor list call-900
member 900
dial-peer cor list call-976
member 976
dial-peer cor list user-internal
member internal
dial-peer cor list user-local
member internal
member local
dial-peer cor list user-domestic
member internal
member local
member domestic
dial-peer cor list user-international
member internal
member local
member domestic
dial-peer cor list user900-internal
member internal
member 900
member 976
dial-peer cor list user900-local
member internal
member local
member 900
member 976
dial-peer cor list user900-domestic
member internal
member local
member domestic
member 900
member 976
dial-peer cor list user900-international
member internal
member local
member domestic
member 900
member 976
dial-peer voice 3 pots
corlist outgoing call-local
description ** T1 PRI pots dial-peer **
destination-pattern 9T
dial-peer voice 4 pots
corlist outgoing call-domestic
dial-peer voice 5 pots
corlist outgoing call-international
destination-pattern 900T
dial-peer voice 6 pots
corlist outgoing call-900
destination-pattern 91900.......
dial-peer voice 7 pots
corlist outgoing call-976
destination-pattern 91976.......
dial-peer voice 8 pots
incoming called-number .
direct-inward-dial
dial-peer voice 9 pots
destination-pattern 911
forward-digits all
dial-peer voice 11 pots
dial-peer voice 12 pots
dial-peer voice 13 pots
dial-peer voice 14 pots
dial-peer voice 15 pots
dial-peer voice 16 pots
direct-inward-dial
dial-peer voice 74 voip
description ** cue voicemail pilot number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 600
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 75 voip
description ** cue auto attendant number **
destination-pattern 601
codec g711ulaw
no vad
dial-peer voice 76 pots
destination-pattern 250
port 0/1/0
dial-peer voice 77 pots
port 0/3/0
forward-digits 1
Re: Prefix FXO line
telephony-service
load 7960-7940 P00307020200
load 7970 P00307020200
load 7906 P00307020200
max-ephones 150
max-dn 480
ip source-address 10.10.10.1 port 2000
auto assign 110 to 120
caller-id block code *916
calling-number initiator
service phone videoCapability 1
system message Banque Atlantique
time-zone 5
date-format dd-mm-yy
voicemail 600
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh music-on-hold.au
web admin system name admin secret 5 $1$kscD$yxr4NQKAcnqvH1nO/QPgT/
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern .T
create cnf-files version-stamp 7960 Dec 20 2008 09:06:21
ephone-dn 1
number 301
name IP-Paging1
paging ip 239.1.1.1 port 2000
ephone-dn 2
number 302
name IP-Paging2
paging ip 239.1.1.2 port 2000
ephone-dn 3
number 303
name IP-Paging3
paging ip 239.1.1.3 port 2000
ephone-dn 4
number 304
name IP-Paging4
paging ip 239.1.1.4 port 2000
ephone-dn 5 dual-line
number 100 secondary 4085551000
label 100
description User Name
name CISCO
call-forward busy 600
call-forward noan 600 timeout 15
corlist incoming user900-international
ephone-dn 6 dual-line
number 101 secondary 4085551001
label 101
name User Name
ephone-dn 7 dual-line
number 102 secondary 4085551002
label 102
name User Name
ephone-dn 8 dual-line
number 103 secondary 4085551003
label 103
name User Name
ephone-dn 9 dual-line
number 104 secondary 4085551004
label 104
name User Name
ephone-dn 10 dual-line
number 105
label 105
name User Name
ephone-dn 151 dual-line
number 246
label 246
name User Name
ephone-dn 152 dual-line
number 247
label 247
name User Name
ephone-dn 153 dual-line
number 248
label 248
name User Name
ephone-dn 154 dual-line
number 249
label 249
name User Name
ephone-dn 155
number 800...
mwi on
ephone-dn 156
number 801...
mwi off
ephone-dn 157
number 701
park-slot
ephone-dn 158
number 702
park-slot
ephone-dn 159
number 703
park-slot
ephone-dn 160
number 704
park-slot
ephone-dn 161
number 705
park-slot
ephone-dn 162
number 706
park-slot
ephone-dn 163
number 707
park-slot
ephone-dn 164
number 708
park-slot
Re: Prefix FXO line
ephone 1
video
mac-address 0022.90BC.20A8
username "100" password 0000
type 7960
button 1:5
pin 0000
ephone 2
video
mac-address 001C.58F9.8BE1
after-hour exempt
username "user2" password 101
type 7970
button 1:6
ephone 3
video
mac-address 0000.0000.0003
username "user3" password 102
type 7960
button 1:7
ephone 4
video
mac-address 0000.0000.0004
username "user4" password 103
type 7960
button 1:8
ephone 5
video
mac-address 0000.0000.0005
username "user5" password 104
type 7960
button 1:9
ephone 6
video
mac-address 0000.0000.0006
username "user6" password 105
type 7960
button 1:10
ephone 7
video
mac-address 0000.0000.0007
username "user7" password 106
type 7960
ephone 8
video
mac-address 0000.0000.0008
username "user8" password 107
type 7960
ephone 9
video
mac-address 0000.0000.0009
username "user9" password 108
type 7960
ephone 10
video
mac-address 0000.0000.0010
username "user10" password 109
type 7960
ephone-hunt 1 sequential
pilot 501
final 600
statistics collect
ephone-hunt 2 sequential
pilot 502
final 600
statistics collect
ephone-hunt 3 sequential
pilot 503
final 600
statistics collect
ephone-hunt 4 sequential
pilot 504
final 600
statistics collect
alias exec cue service-module service-engine 3/0 session
line con 0
line aux 0
line 194
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
privilege level 15
password cisco
login local
transport input telnet ssh
scheduler allocate 20000 1000
ntp master
ntp server 10.10.10.1
end
CallManager#
Re: Prefix FXO line
looks like fine from the config point of view except im not getting why there is NO T1/E1 for all your dail-peer !!! local LD and international there are not pointing to anything ??!!
now let me understand you well, if you pick up a phone a call "0" only the 4 FXS ports are ringing ??!!!
if yes try to configure :
ephone-dn x
number 0
call-forward all 100
and make sure you can call 100 directly which is the FXS port !!
hope will help..HTH
Re: Prefix FXO line
Actually my analog phone have the number 250
port 0/1/0
All all extension can call the analog phone
I have put the number "0" to take the FXO port 0/3/0
port 0/3/0
forward-digits 1
When I dial the number 0 I see an activity on the FXO card but I have no tone
Re: Prefix FXO line
now port 0/3/0 is FXO not FXS ?
if yes what are you trying to achive from your setup ?
call 0 as access code to get line then call outside ?
Re: Prefix FXO line
Port 0/3/0 = FXO
Port 0/1/0 = FXS
Phone 250 is connected on FXS port 0/1/0 and I want dial 0 to take the line 0/3/0 to send an outgoing call.
Re: Prefix FXO line
port 0/3/0
forward digits 7
try that
Re: Prefix FXO line
With it's running
port 0/3/0
forward digits 0
Re: Prefix FXO line
your config :
port 0/3/0
forward digits 0 <-- this will not send any digit to FXO, so it wont work.
you need to send the calles number to FXO in order to make your call
regards
393
