Community Member
Prefix in Voip dialpeer !
Hi there,
We have an Access Server here, when I try to create a voip dialpeer pointing to a new CCM SUB we just added, the dialpeer is created but when I type the command
show dial-peer voice summary
it seems it is created with a prefix 01, I am not able to delete this prefix, and when I try to check the dialpeer configuration I do not find this prefix at all!!
However when I create a dialpeer pointing to the existing CallManagers, it is created without this prefix !
Apprecaite any assistance please, thanks a lot.
Hall of Fame Super Gold
Re: Prefix in Voip dialpeer !
Maybe is a leftover from a previousl pots DP with the same tag, that had prefix.
It is a cosmetic issue that you can ignore.
Community Member
Actually it is causing problems because when a called number matches this dialpeer, the call fails with the disconnect cause "network out of order (38)"
Any ideas??
Voip DP support no prefix, so that is not the cause.
You can recreate the DP under another tag anyway, but it will still fail according to the statement abvove.
358
