Prefixing 88 on FXS port calls not working
I've followed several cisco documents and double checked my translations, but on the FXS voice port the translation-profile is not prefixing 88 on to the number dialed from device on FXS port. I want the calls to hit the 201 dial peer, which then sends the call to call manager. I have a PSTN 91... dial peer for outbound calls so purpose of this to steer calls from FXS ports to hit CUCM first.
Any ideas?
voice translation-rule 1
rule 1 /9/ //
voice translation-rule 2
rule 1 /999/ //
voice translation-rule 3
rule 1 /\(.*\)/ /88\1/
voice translation-rule 4
rule 1 /88/ //
voice translation-profile Prefix8
translate called 3
voice translation-profile Strip88
translate called 4
voice-port 0/0/0
translation-profile incoming Prefix8
dial-peer voice 201 voip
destination-pattern 88T
modem passthrough protocol codec g711ulaw
session protocol sipv2
session target ipv4:10.10.10.10
voice-class sip profiles 1
dtmf-relay rtp-nte
codec g711ulaw
fax-relay sg3-to-g3
fax rate 9600
ip qos dscp cs3 signaling
no vad
The test commands shows the translation rule prefixing the 88
GATEWAY#test voice translation-rule 3 915556667777
Matched with rule 1
Original number: 915556667777   Translated number: 88915556667777
Original number type: none      Translated number type: none
Original number plan: none      Translated number plan: none
Hall of Fame Super Gold
Some IOS version have bugs for which translation profiles are not applied, so you have to update.
You can also rewrite the rule more efficently as:
rule 1 // /88/
Do you have a bug id for this behavior?
Were on recent 15.1T IOS and I've gone through all the release notes for 15.1T, 15.2, 15.3 and not seeing anything for FXS ports or translation rules/profiles.
Do you know of an alterate way to do this that doesn't require a bunch of dial peer magic? I also tried the simpler rule earlioer and neither work, and I also tried the old style translation rule command on fxs ports with no success either.
Erick
I don't see that the rule has been applied to the dial peer. Take a look at the following document:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
RG
The translation profile is applied to the FXS voice-port directly I want the 88 prefixed to the call on all calls from devices on that FXS port.
so if a FAX machine/etc dials 91XXXYYYZZZZ the voice-port translation adds 88 to it, so it becomes 8891XXXYYYZZZZ then hits the 88T dial peer to go to call manager. Right now, it is not hitting this dial peer and hitting a 91T dial peer and going to PSTN directly.
Re: Prefixing 88 on FXS port calls not working
Hi ebergquist,
Try a translation rule (old school way of doing it) rather than a voice translation rule and profile.  I've seen this work where the new method does not.  Eg:
translation-rule 1
rule 1 . 88
voice-port 0/0/0
description FXS port
translate called 1
Jonathan
Thanks, The old style translation rule worked. I had tried that before but forgot the rule syntax was different.
Which exact IOS are you running? So we know it's broken.
298
