prefixing extra numbers on dial-peers
how can i add some extra digits without informing users. Lets say if users dialing 90501234567, at backend, i want to add 9088880501234567.
  • IP Telephony
Everyone's tags (5)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Just change prefix 05 to 908888050, so it should look like this:
dial-peer voice 13 pots
prefix 908888050
Chris
If I remember correctly this can be done using a translation pattern to add extra digits along with "no supplementary-service h225-notify cid-update" to prevent the phone display from changing.
If this is a pots dial peer you can simply add "prefix" command to the dial peer, if this is on voip dial peer you will need to use translation rule. The command Joe is referring should prevent the user from seeing the updated dialed number, though that will only work for H323 GW, if you are using SIP I would imagine you would need to add a sip profile and modify the header.
HTH,
Chris
description Mobile
destination-pattern 905........$
port 0/0/0:15
prefix 05
where will i add? at dialpeer or in cucm (route pattern)
prefix 908888050
Chris
Thanks, it worked.
459
