03-08-2007 02:25 AM - edited 03-14-2019 08:22 PM
Hi all,
I have an issue as i have seen on this forum many times before regarding prexing incoming calls. I know that there is a way on H323 gateways and a way on MGCP using translations BUT..... when you add the mask for the translation it will not catch all numbers for example many countries have a different amount of digits on their numbers so they system will not match that in the mask and add either a ? or cut the digits it cant match.
Has anyone else experienced this issue and solved it?
Any help would be gratefully received.
03-08-2007 04:44 AM
Which gateways are you using? What system are you using - CallManager or CME?
03-08-2007 05:51 AM
i'm currently using 3725, MGCP and CCM. I looked on tac case collection and they know its and issue but do not have a date for a fix
