Preparing CCIE Collaboration lab v4
Hi all,
I am going to prepare my CCIE Collaboration lab v4 with minimal losses, can I use my CCIE voice v3 lab.
Can I install CME v9 on my router 2811? If yes, what I need to uprgard in my router?
I already have these equipments what I should provide extra
PSTNRouter 2811
1Flash 256
1PVDM2-32
1VWIC2-2MFT-T1/E1
1VWIC2-1MFT-T1/E1
1HWIC 2T
1HWIC 1T
HQ (A)Router 2811
1Flash 256
1PVDM2-32
1VWIC2-1MFT-T1/E1
1HWIC 1T
1Switch 3750/24 ports   PoE
BR (B)Router 2811
1Flash 256
1PVDM2-32
1VWIC2-1MFT-T1/E1
1HWIC 1T
1AIM-CUE
1Switch 3550/24 ports   PoE
BR (C)Router 2811
1Flash 256
1PVDM2-32
1VWIC2-1MFT-T1/E1
1HWIC 1T
1HWIC 4ESW
I need your advice
Abdu
1 ACCEPTED SOLUTION
Hi.
For some part of the lab you can use your 2800 for instance as PSTN router or gatekeeper.
Here is the list of Hardware and IOS version that you should expect at the lab location
https://learningnetwork.cisco.com/docs/DOC-20807
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
https://learningnetwork.cisco.com/community/certifications/ccie_collaboration/lab_exam?tab=studylearn
For CME ver 9 you need IOS 15.2(2)T, unfortunately 2800/3800 series routers latest IOS release is 15.1(4)M6 = CME 8.6
For CME 9 you need a 2900/3900 series router.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Re: Preparing CCIE Collaboration lab v4
Hi Jorge Armijo,
Thank you for replying,
what about the other equipment's, can I use them for example can I use one Router 2900 for CME 9 and use the other 3 Routers 2800 at the PSTN and branches OR can I use two Routers 2900 one in HQ and the second for CME branch and the other two routers keep them 2800.
Actually I don't want to waste my currently lab, is there any way to preserve as much as possible my own lab.
Abdu
Hi.
Carlo
691
