Presence 6.x configuration
All, I hate to be a bonehead on this, but Im having somewhat of a hard time with the Presence configuration. I have this installed, but not really sure where to go or what needs to be done in the configuration. Anyone with any experience in this have a "checklist" of what should be done that they would share? Id appreciate the help.
Green
Re: Presence 6.x configuration
Thanks, I found the deployment guide. This should help alot. Thanks again.
Green
No problem, if you have any issues, please continue posting here
As a side note, the guide will lead you to setup the application > Cisco Unified Personal Communicator > Settings. What TFTP ip address is suppose to be entered here? I don't see TFTP as a service active in the control panel of the CUPS.
Bronze
Once the Presence is up it has an installtion check list you can run through that should help you complete the install. Check the Presence Admin
Cheers
Paul
135
