Presence Call List for 9951
Hello Everyone,
I have an enviroment of UCME running on the top of  ISR router we have configured Presence call list but looks like it did work for sccp and not for SIP Phone 9951 (sip9951.9-1-1SR1) I made eveything follow every thread and did all the required configuration I even reloaded the router but look like it do not work for SIP and work fine for sccp.
Sample of configuration:
presence
presence call-list
max-subscription 500
watcher all
allow subscribe
and I configure allow watch command under all DNs.And I doubled checked my configuration this odd I appreciate the Expert guide to address and solve this issue.
thanks and Regards,
Hi Karim,
Can you please check the config as per the following link
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmepres.html#wp1010561
If it does not work please share the running config from the CME.
Manish
Dear Manish,
I already followed cisco guide that you sent and here is my configuration below:
presence
presence call-list
watcher all
allow subscribe
sip-ua
mwi-server ipv4:192.168.1.7 expires 3600 port 5060 transport udp unsolicited
registrar ipv4:192.168.1.1 expires 3600
sip-server ipv4:192.168.1.1
host-registrar
presence enable
refer-ood enable
voice register global
mode cme
source-address 192.168.1.1 port 5060
bandwidth video tias-modifier 512000 negotiate end-to-end
timeouts interdigit 3
max-dn 100
max-pool 100
authenticate register
authenticate realm cisco
timezone 29
date-format D/M/Y
voicemail 800
url directory http://192.168.1.1/localdirectory
file text
create profile sync 0003561540386854
camera
video
voice register dn  1
number 222
call-forward b2bua noan 800 timeout 15
allow watch
shared-line max-calls 16
mwi
voice register dn  2
number 333
call-forward b2bua busy 800
allow watch
mwi
voice register dn  3
number 444
allow watch
mwi
voice register dn  4
number 555
call-forward b2bua all 111
allow watch
mwi
voice register dn  5
number 666
allow watch
mwi
voice register pool  1
id mac xxxx.xxxx.xxxx
type 9951
number 1 dn 1
cor incoming int-CSS default
presence call-list
dtmf-relay rtp-nte sip-notify
voice-class codec 1
no vad
after-hour exempt
username neo password 12345
conference drop-mode creator
conference admin
camera
video
voice register pool  2
type 9951
number 1 dn 2
voice-class codec 1
after-hour exempt
conference admin
camera
video
voice register pool  3
type 9951
number 1 dn 3
voice-class codec 1
after-hour exempt
voice register pool  4
type 9951
number 1 dn 4
voice-class codec 1
after-hour exempt
voice register pool  5
type 9951
number 1 dn 5
voice-class codec 1
after-hour exempt
voice-class codec 1
after-hour exempt
Hi Karim,
The config looks good, which firmware is running on the 9951's? It may be affected by the following
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtq39163
Presence BLF support on Call History feature development
Symptom:
This feature is a parity of the TNP phones. It  enables the users to see the presence status of the line numbers in the  Call History list for 9971/9951/8961.
Conditions:
Enable the enterprise parameter "BLF For Call Lists".
Workaround:
None
Can you please upgrade to the latest firmware available for 9951 from cisco.com and test it.
Manish
Thank you Manish for your reply I will do upgrade for one phone and update you with the results.
293
