Presence Install Question
angel-moon
Level 3
Level 3
Hello everyone,
I'm a bit confused.  If I download the OVA template for Presence and and deploy it on the VM does that include the install program for Presence or or do I still need install media?
Thanks in advance!  All replies rated.
Jaime Valencia
All our OVAs are just the VM specs, you need to have install media and do the actual install for any product.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
Thanks again (for the 100th time!)
Is the media for Presence downloadable from Cisco?
Nope, fresh install media is not downloadable from CCO. You need to order it via PUT.
java
java
The PUT tool asks for a Contract Number.  If this is a new install on an MCS system how do you go about getting the media/contract number?
Joe
