Preventing isdn layer 3 going down on an BRI
s-bruening
we have BRI Port configured as network side:
interface BRI0/2/1
no ip address
isdn switch-type basic-net3
isdn protocol-emulate network
isdn point-to-point-setup
isdn layer1-emulate network
isdn incoming-voice voice
isdn skipsend-idverify
line-power
To this port an isdn phone is connected.
Outgoing calls from this isdn phone to the PSTN are no problem and working fine. But incoming calls to this port are only successfull some secondes ago after last external call from the connected isdn phone.
The problem is that some seconds after the last outgoing call from the isdn phone the isdn layer 3 is going down and the isdn status is going back to Tei-assigned.
Is there a command to prevent that isdn layer 3 is going down when it is inactive?
paolo bevilacqua
These are symptoms of layer1 going down, not just layer3.
You can collect "debug bri" and "debug isdn q921" to see what's going on, but there is no configuration you can apply to fix.
So you could just try upgrading IOS in the hope the issue goes away, it may or may not.
