PRI Call Failing via ISR voice gateway
  • IP Telephony
Bronze
I think you need to investigate further by having "debug isdn q931" and "debug isdn q921" at both gateways. There could be multiple reasons for this error which are described in below link. Traces will help us to come to a conclusion.
http://www.mail-archive.com/ccie_voice@onlinestudylist.com/msg07948.html//www.mail-archive.com/ccie_voice@onlinestudylist.com/msg07948.html
Regards...
-Ashok.
With best regards... Ashok ----------- Pls kindly rate if helpful or answered your question.
Green
Re: PRI Call Failing via ISR voice gateway
Try adding this to the config on both routers
voice service voip
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  transport switch udp tcp
sip-ua
And on the VOIP dial peers on both routers
add
dtmf-relay sip-notify rtp-nte
Alex
Regards, Alex. Please rate useful posts.
405
