PRI Calling Name without MGCP
I have an H.323 gateway with a PRI that is recieving calling name from the PSTN. I know that this is supported with MGCP, but I was looking to keep this feature with an H323 or SIP gateway.
Can this be done?
Frank
Hall of Fame Super Gold
Re: PRI Calling Name without MGCP
Yes, that should work, worst case you need an IOS update.
What should work? Sip or H323? I have it configured now as a SIP gateway using a SIP trunk to my callmanager. When I call into my IP Phone I see the the remote-party-id=pending in the SIP INVITE followed by a SIP INFO message containing the correct remote-party-id (As shown in the following link, http://www.cisco.com/en/US/docs/ios/voice/sip/configuration/guide/sip_cg-isdn_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1062842).
It seems that callmanager does not wait for the SIP INFO message.
Frank
SIP is not a common configuration for GW trunking to CM. You could try H.323 instead.
209
