PRI channel betwen CCME and PBX Panasonic
Good day!
I want to create a channel between CCME on my cisco 2901 and PBX Panasonic TDE-600. On my PBX Panasonic i have one PRI Board with a PRI port (not T1/E1, cause T1/E1 exist for such PBX, but i dont have it), so what EHWIC module i should use on my 2901 to create a PRI channel betwen this two devices and connect it?
Everyone's tags (3)
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
leosalcie wrote:
You can use a HVWIC2-1MFT-T1E1 card for T1CAS/PRI or E1.
The correct P/N is is VWIC2-1MFT-T1E1 or VWIC3-1MFT-T1E1. Also need PVDM3-32 (minimum).
Re: PRI channel betwen CCME and PBX Panasonic
Yes, it is.
Thank you for the nice rating and good luck!
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
I have only PVDM3-16, isnt enough?
I can config to use only 10 time slots, not all 30, cause have only PVDM3-16, is it?
Thanks;)
Yes, it is.
Thanks a lot:)
I've rating your useful posts
378
