PRI channel hunting
George Thomas
Level 10
Level 10
Is it possible to change the order of hunting a channel in a PRI to circular/round robin? Thanks in advance.
Please rate useful posts.
paolo bevilacqua
There might be a way, but it's quite complicated. Why are you asking ?
There is a 3rd party product integrated using a PRI and vendor recommends hunting of channels instead of top/down.
You can change the order like ascending / descending by using the command
isdn bchan-number-order ascending/descending.
And there is no other hunting method that can be configured i guess.
Siva
Pls rate if helps you.
In this case 'unsubstantiated vendor recommendation' I suggest to stick to what COs have done for since the beginning, first-available channel..
