Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
PRI channel hunting
Is it possible to change the order of hunting a channel in a PRI to circular/round robin? Thanks in advance.
Please rate useful posts.
Hall of Fame Super Gold
Re: PRI channel hunting
There might be a way, but it's quite complicated. Why are you asking ?
There is a 3rd party product integrated using a PRI and vendor recommends hunting of channels instead of top/down.
PRI channel hunting
You can change the order like ascending / descending by using the command
isdn bchan-number-order ascending/descending.
And there is no other hunting method that can be configured i guess.
Siva
Pls rate if helps you.
In this case 'unsubstantiated vendor recommendation' I suggest to stick to what COs have done for since the beginning, first-available channel..
521
