Community Member
PRI Channels
Dear All,
Is there any command on router to find out how many PRI channels are provided by telco?
Thaks
1 REPLY
Super Bronze
Re: PRI Channels
Yep - ask them!
Alternatively you could start with say 8 channels configured, and if you can send on the 8th channel, then reconfigure your PRI to have more channels (e.g. 16) and try sending a call on that.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
129
