PRI CIC code ISDN
We have a new pri installed and the telco will not be the LD provider...they are requesting that we send the CIC code for the appropriate LD provider (MCI)...The PRI is isdn switch type NI2.
The gateway is an H.323 gateway...CCM 5.04....is the possible?
Joe
Hall of Fame Super Gold
Re: PRI CIC code ISDN
Absolutely possible.
I'm not expert at CM but I think you can configure the CIC there, or you can do that on the gateway, with a tranlation-rule (matches LD, insert CIC).
I have tried to change it the CIC in CCM but with the isdn switch type of NI2 the CIC information is grayed out...so if I try to do a translation rule I assume I would match 91XXXXXXXXXX ...and add the CIC code...will this cause issues with toll free numbers as well?...
Joe
Hi Joe,
again I'm not an expert at CM, but I assume that you can configure the order in which translations are applied, so you will have "match toll free, do nothing, no more translations" before before "match LD, insert CIC".
277
