PRI config guide on ISR 2800-UAE
I have terminated PRI into ISR 2800. All config is ok interims linecoding, framing, clock source etc. PRI line is tested by ISP-Ok.
But it shows E1 down in sh commands with the status LED yellow.
Is there any specific setting to be done for UAE regions??
Hall of Fame Super Gold
Re: PRI config guide on ISR 2800-UAE
Send output of "show controller E1", and check your cabling.
E1 is the same in all the world.
After issuing the same command i can get " receiver has remote alarm" rest all looks fine.
Check cabling, receiver is not seeing router signal.
Plz find the config & sh controller output.
You probably have a major cabling problem, which cabling are you using now ?
I am sorry..i didn't get your question (i am using cabling 1245)
What is the cable that goes from router to telco ? Is telco 120 Ohm / unbalanced ?
Do you mean pins 1-2 and 4-5 of RJ-45? Are you respecting pair twisting ?
After the cable is OK, if still problems, the circuit is defective. There are no other alternatives.
Yes..it is 120Ohm/unbalanced...Pins 1-2 & 4-5 been used..As per the ISP the PRI line is tested OK...Any suggestions..
Invite SP on premises and have them place and receive calls using a test device, in front of you.
440
