06-02-2010 06:29 AM - edited 03-15-2019 11:03 PM
Hi Experts,
What are the ISDN- E1 configuration commands for new Cisco router 2951 ,which got the IOS version 15.X. I am not able to do it on the new series router.
Please suggest.Thanks in advance!
06-02-2010 07:35 AM
The commands are the same.
Have you checked that you have the voice package to do that???
EDIT: Review the new IOS model here
http://www.cisco.com/en/US/partner/prod/collateral/routers/ps380/ISRG2_DeploymentGuide.pdf
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
06-02-2010 08:06 AM
yes i have checked. I am not able to use any ISDN commands.
06-02-2010 11:55 AM
Do you have DSPs to use the PRIs?
java
06-03-2010 06:47 AM
At first you must have the right IOS for voice in the router.
At second: what E1 interface you have? possible you must do something like this: card type e1 0 0 prior you can set ISDN commands.
Look at this as an example:http://www.cisco.com/en/US/docs/routers/access/1700/1721/software/feature/guide/t1e11721.html#wp142465
