03-24-2009 08:59 AM - edited 03-15-2019 05:03 PM
Hi Pros,
There is the issues, I have two pries. The way they set up now deny all call coming from an unknow number(caller ID not listed). IS there a way, I can have the pri to accept the call even the other party does not need to show his number?
Crazy
03-24-2009 09:39 AM
Yes. In fact, the configuration that you have is not normal and you should look at the details of how it was achieved.
03-24-2009 10:16 AM
Hi p.evillacgua,
What do you mean by it not normal? This configuration is till forwarding call as usual. The only issue is that unknown caller id .
Crazy
03-24-2009 10:22 AM
I mean, it is not normal that calls without a CLID are rejected. This does not happen by default, possibly it is happening at telco level.
