PRI (E1) Mexico - MGCP gateway
Has anyone ever configured VWIC MFT 1-Port E1/T1, 2811 router. The router is currently installed in Mexico, and we are trying to connect to PSTN. The provider is Telmex. The gateway is configured via MGCP.
Here is a part of the config:
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
isdn switch-type primary-net5
voice-card 0
dspfarm
dsp services dspfarm
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31 service mgcp
interface Serial0/0/0:15
no ip address
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
voice-port 0/0/0:15
cptone MX
Here is the output of the debug isdn q921
*May 6 20:30:01 CET: ISDN Se0/0/0:15 Q921: L2_EstablishDataLink: sending SABME
*May 6 20:30:01 CET: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*May 6 20:30:02 CET: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*May 6 20:30:03 CET: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*May 6 20:30:04 CET: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*May 6 20:30:11 CET: ISDN Se0/0/0:15 Q921: L2_EstablishDataLink: sending SABME
The output of show controllers e1:
E1 0/0/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20060707, FPGA: 13, spm_count = 0
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (97 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 1 15 minute intervals):
0 Line Code Violations, 0 Path Code Violations,
1 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
1 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
The tei esthablisment in not been done. Telco says they received a Multiframe-error.
Thanks a lot.
Re: PRI (E1) Mexico - MGCP gateway
Did you verify w/telco the correct ISDN switch-type to use, as well as the correct framing and linecode settings?
The framing and linecode settings are correct NO-CRC and HDB3 the onlything about ISDN type is that the telco gives a strange answer about that. The only thing is that the voice gateway is connected via an CAB-E1-RJ45BNC= to the Telmex equipment. On Cisco I have read about a R2 connection in Mexico but I don't know if this is for voice calls.
Try playing with the changing the ISDN switch type, make sure they match in the call manager and the gateway. However, Im not too familiar with R2 signaling, as I am here in the US, but I do know that you should check with your telco to get the exact settings you need to configure. example configuration
ds0-group 0 timeslots 1-31 type [line-signaling-type] [interregister-signaling-type] ani service mgcp
Hi, R2 is also for voice. Here is an example for the E1 controller in Mexico.
framing NO-CRC4
clock source line primary
line-termination 75-ohm
ds0-group 1 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 1
unused-abcd 0 1 1 1
country telmex
seizure-ack-time 30
disconnect-tone
category 2
signal-end-to-end
answer-signal group-b 1
caller-digits 4
dnis-digits min 4 max 13
ani-digits min 0 max 10
dnis-complete
answer-guard-time 750
ani-timeout 10
groupa-callerid-end
If this helps pls rate
Vhilario
According to my researsches
According to my researsches it is impossible to set the GW as MGCP up. Is this correct?
1327
