PRI echo
We have a new CCM 5 installation with a pri...the customer has reported problems with echo...we are in the process of getting data from calls that have echo but since the problems are sporatic we are not able to get alot of good data...
This is the output of a show call active voice a call that had a test tone generated on it...
TxDuration=114875 ms
VoiceTxDuration=114875 ms
FaxTxDuration=0 ms
CoderTypeRate=g711ulaw
NoiseLevel=-82
ACOMLevel=63
OutSignalLevel=-15
InSignalLevel=-79
InfoActivity=1
ERLLevel=45
EchoCancellerMaxReflector=4
The setting on voice-port are input gain -3 ...my main issue is why is the
InSignalLevel=-79 such a large number...I would think this would -18...
From my understanding echo on a pri is not common...am I missing something...
Joe
Re: PRI echo
What kind of voice gateway and version of IOS are you running?
Re: PRI echo
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(3g), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 06-Nov-06 02:36 by alnguyen
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
bk0014_Main_2811 uptime is 8 weeks, 22 hours, 3 minutes
System restarted at 17:30:33 EST Wed Jan 17 2007
System image file is "flash:c2800nm-spservicesk9-mz.124-3g.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.51) with 251904K/10240K bytes of memory.
Blue
Re: PRI echo
Joe,
The -79 is actually a very low level as the reference is 0db. The OutSignalLevel is your test tone.
On our IOS gateways with PRIs I have found that the worst case erl needs to be changed from the default 6db to 3 in order to eliminate all echo problems. This means that a echo signal 3db or more below the transmit level will be cancelled.
voice-port 1/0:23
echo-cancel erl worst-case 3
It is the far end termination of the call that causes echo. So if you place a call over your PRI that terminates on another PRI it would be unusual for you to hear echo. If you place a call over your PRI that terminates on an analog line with bad return loss (high reflection) you will hear echo.
Here is a good doc:
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a0080149a1f.shtml
Please rate helpful posts.
Dave
Re: PRI echo
Joe,
I've got the same sporatic echo issue to calls to/from a PRI. I am using a 2821 w/12.4(3g). I am working through a TAC case, and have already been through the playing with input gain, and output attenuation. I have also been through the different echo cancel settings.
Have you had any luck figuring this out?
Re: PRI echo
Go into your router and do:
show voice dsp detailed. You will see a version of your DSPWare firmware. If it is 4.4.19 or prior, there is a known bug that causes echo under certain conditions.
Re: PRI echo
I noticed the bug when started troubleshooting this issue...unfortunately we are not affected:
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABRT PACK COUNT
C5510 001 01 {flex} 4.4.20 alloc idle 0 0 0/0/0 02 0 5734/0
C5510 001 02 {flex} 4.4.20 alloc idle 0 0 0/0/1 06 0 2726/0
C5510 001 03 {flex} 4.4.20 alloc idle 0 0 0/0/2 10 0 2956/0
C5510 001 04 {flex} 4.4.20 alloc idle 0 0 0/0/3 14 0 2394/0
Joe
Re: PRI echo
Joe,
My nearly identical problem with a 2821 and 12.4(3g) was resolved by moving to 12.4(7e). I've gone almost 4 full business days without hearing of any echo. I was hearing 2-3 consistent reports of echo each day before this IOS upgrade.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dde2b48/12#selected_message
Good luck.
Jeff
792
