10-24-2013 01:27 AM - edited 03-16-2019 08:02 PM
Hi All,
I am facing PRI Fluctuation , beacuse of which Call are diconnected on regular intervals.
below is the error which is gettin on Router Voice Gateway
10-24-2013 01:35 AM
Hi Vijay,
the snapshot shows RAI[remote alarm indication] detected which is mainly due to Far end in your case it is TELCO.The other error is due to clocking.if possible,please post your config.
Did u get your media checked by TELCO?
regds,
aman
10-24-2013 01:36 AM
Hi Vijay.
This usually is a cabling issue from the vg PRI to the provider device.
Check with your local provider an , if you can, the cable connecting PRI interface.
Please also post a show controller E1
Carlo
Please rate all helpful posts
"The more you help the more you learn"
10-24-2013 01:50 AM
E004010102CRR#sh controllers e1
E1 0/0/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info FPGA Rev: 08121917, FPGA Type: PRK1
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
International Bit: 1, National Bits: 11111
Data in current interval (887 seconds elapsed):
0 Line Code Violations, 10 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
259 Errored Secs, 21 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 2432 Path Code Violations,
8 Slip Secs, 1418 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
7156 Errored Secs, 916 Bursty Err Secs, 0 Severely Err Secs, 1450 Unavail Secs
10-24-2013 01:52 AM
Hi Vijay
You have to check with your Teleco , that means the other equipment on the other side disconnected or out of service and please check the isdn switch-type may be is mismatched with your SP. Please check the below link which shows your problem :-
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00800a70f6.shtml
Thank you
Please rate all useful information
10-24-2013 02:06 AM
Hi Vijay,
To troubleshoot further, u can try changing CRC parameter under controller config.
Further, u can also give loopback local from controller port to check your cable and E1 port .
loopback remote from controller E1 port to check the media end to end by involving TELCO.
regds,
aman
10-24-2013 02:12 AM
Hi Amanso
Great idea for disable also CRC4 , but i think this should be done from Teleco side.
Hi Vijay
you have all possible solutions now, please start with contacting your Teleco.
Thank you
