pri-group vs. ds0-group
I'm hoping someone can help me out. I'm very confused as to when Pri-group vs. ds0-group should be used. My understanding is that pri-group should be use when the telco is delivering a PRI with SS7 equipment to your location, and that ds0-group should be used when a CAS line or channelized T1 has been delivered. Recently I've run into situations during testing where a given router would tell me that I did not have enough resources to create a pri-group, but would let me create a ds0-group without incident. Hopefully someone can provide a better explanation than what I have received previously as I am very interested in understaing this concept better.
Steve
Re: pri-group vs. ds0-group
Hi I too have the doubt. Waiting for Experts comments
thanks
Tam
You assumption is a correct. If you have a PRI with a D-Channel, you set up a PRI group. CAS and channelized are DS0 groups. You need at least a PVDM-32 installed in the router to bring a PRI up. You don't need that for DS0 groups.
Great information! Thanks.
Is there something that I need to do to "assign" the DSP channels to the PRI? I have a PVDM2-64 in the router, but I am still getting the "Not enough resources" error message.
Steve
On th egateway do you have the card type configured correctly?
As well as do you have the timeslots on the controller defined?
Sorry you also need the network clock assigned.
I have card type wic 0 0 t1, but I bet I'm missing the network clock assignment!
Thanks!
2516
