PRI issue with new NM-HDV2-2T1/E1
i replaced a nm-hdv2 with an nm-hdv2-2t1/e1. after i replaced the hardware and connected the PRI to the new port i cant place outgoing calls. i changed the configuration on the router.
i have the interface configured like this:
interface Serial1/0:23
no ip address
isdn switch-type primary-ni
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
i changed the voice port to reflect the new interface number:
voice-port 1/0:23
input gain -2
output attenuation 2
dial peer like this:
dial-peer voice 103 pots
application mgcpapp
port 1/0:23
there must be changes in call manager?
thanks in advance.
Re: PRI issue with new NM-HDV2-2T1/E1
Jerry,
Are you able to receive inbound calls ?
What is the status of isdn interface ?
Can you paste a sh isdn status output ? Also include show mgcp and show ccm-manager output.
Can you please send a sh run.Since this is a E1 you dont need the following:
application mgcpapp
port 1/0:23
The above is needed only for fxs/fxo mgcp endpoints.
You might want to check your route pattern,route list config.A ccm trace would be useful here to determine if the call is even getting to the gateway here
193
