10-30-2013 01:27 AM - edited 03-16-2019 08:08 PM
When i am doing call from GW e using isdn test call interface se0/0/0:15) outgoing work fine But end user are not able to make outgoing although they are able to receive calls.
10-30-2013 01:46 AM
do you see the call hitting the GW from IP phone? If the call is not coming into GW, it is something you need to check the Route Pattern and GW config in CUCM side.
if the call is coming to GW, could you please post the debug voice ccapi inout and debug isdn q931 for a test call with calling number, called number and also the complete configuration.
10-30-2013 01:52 AM
Hi Vijay,
how GW is integrated to CUCM? can u share the GW config.
regds,
aman
10-30-2013 02:08 AM
Hi as already explain call from IP Phone is not hitting to GW...
S0011010101CRR#sh running-config
Building configuration...
Current configuration : 10994 bytes
version 15.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname S0
boot-start-marker
boot-end-marker
card type e1 0 0
no logging console
enable secret 4
aaa new-model
aaa session-id common
clock timezone IST 5 30
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
no ipv6 cef
no ip source-route
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
ip flow-cache timeout active 1
no ip bootp server
no ip domain lookup
ip domain name sbigen.in
ip cef
ip wccp 61 redirect-list DC-PT-Traffic
ip wccp 62 redirect-list DC-PT-Traffic
isdn switch-type primary-net5
voice-card 0
dspfarm
dsp services dspfarm
voice call carrier capacity active
voice rtp send-recv
voice service pots
voice service voip
ip address trusted list
ipv4 172.16.130.0 255.255.254.0
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
h323
session transport udp
h245 tunnel disable
voice class codec 99
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729br8
codec preference 4 g729r8
voice class h323 99
call start slow
voice translation-rule 1001
rule 1 /^[0-9]+/ /0&/
voice translation-rule 1003
rule 1 /^91/ /0/
voice translation-profile FROM_PSTN
translate calling 1001
voice translation-profile TO_PSTN
translate called 1003
license udi pid CISCO2921/K9 sn FGL1641148X
hw-module pvdm 0/0
hw-module sm 1
redundancy
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31
ip ssh time-out 60
ip ssh version 2
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn map address .* plan unknown type unknown
no cdp enable
interface Vlan1
no ip address
interface Vlan22
ip address 10.80.2.1 255.255.255.0
ip wccp 61 redirect in
ip flow ingress
interface Vlan100
ip address 10.80.3.1 255.255.255.0
ip wccp redirect exclude in
ip flow ingress
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.80.3.1
control-plane
voice-port 0/0/0:15
translation-profile incoming FROM_PSTN
mgcp profile default
dial-peer voice 101 voip
description *** Dial-peer to CUCM ***
preference 1
destination-pattern ....
session target ipv4:172.16.130.32
voice-class codec 99
voice-class h323 99
dtmf-relay h245-alphanumeric
fax-relay ecm disable
fax-relay sg3-to-g3
no vad
dial-peer voice 102 voip
description *** Dial-peer to CUCM DR ***
preference 2
session target ipv4:172.18.130.32
voice-class h323 99
fax-relay sg3-to-g3
no vad
dial-peer voice 201 pots
description *** Incoming calls from PSTN***
incoming called-number .
direct-inward-dial
port 0/0/0:15
dial-peer voice 202 pots
description ***Outgoing calls To PSTN***
destination-pattern 0.T
port 0/0/0:15
dial-peer voice 106 pots
description Outgoing calls To PSTN
translation-profile outgoing TO_PSTN
destination-pattern 91T
port 0/0/0:15
gatekeeper
shutdown
call-manager-fallback
secondary-dialtone 0
max-conferences 8 gain -6
transfer-system full-consult
timeouts interdigit 3
ip source-address 10.80.3.1 port 2000
max-ephones 25
10-30-2013 02:26 AM
Please check the DNA whether or not the calls going to GW. Do you get any RTMT RouteList Exhausted Alert while trying outbound calls? if so, what is the cause code?
Please collect the CCM Detailed SDI traces for a test call with calling number, called number
10-30-2013 02:27 AM
Hi Aman,
Please find the Sh run,, any thing else is require
10-30-2013 03:10 AM
Vijay..
please do a test call and post the debug requested by Suresh
1. debug voip ccapi inout
2. debug isdn q931
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
