PRI issue
while testing by ISP on there tester PRI works foine but when the with the same cable we terminate on Router it shows following error.
E1 0/1/0 is down.
  Applique type is Channelized E1 - balanced
  Transmitter is sending remote alarm.
  Receiver has loss of signal.
  alarm-trigger is not set
VIP Super Bronze
PRI issue
This is a layer 1 issue...You need to check your cabling..
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Re: PRI issue
Loss of signal troubleshooting.
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00800fb754.shtml#topic3
One important quote " 4:If you have completed all of these steps and you still experience problems, use a rollover cable."
PRI issue
I checked with Cross-cable same issue,  Service provider check on the PRI tester its works when connect on Router not works,,, I checked with the New Cables...following is the output when we run devug isdn command..
ISDN TEST CALL #0 to XXXXXXXXXX at 64 Kbps failed aborting the remaining 1 calls
PRI issue
Hi Vijay,
Please post your "Show isdn status"
Nishant Savalia
Regards, Nishant Savalia
VIP Purple
PRI issue
Hi Vijay,
check the pairs
should be 1,2 and 4,5 else swap them.
regds,
aman
PRI issue
If cable is fine then you should check the framing and line coding configured under the controller. It must match on your side and ISP side.. You can verify using below command:
Bru#show controllers e1
E1 0 is up.
  No alarms detected.
  Version info of Slot 0:  HW: 2, Firmware: 4, PLD Rev: 2
Manufacture Cookie is not programmed.
Framing is CRC4, Line Code is HDB3, Clock Source is Line Primary.
Piyush Jain
199
