PRI line to CallManagerExpress - enabling caller ID?
How to enable the caller id? When a call arrives from outside via PRI lines to call manager express the users do not see caller ids. How to enable it ?
thx
Hall of Fame Super Gold
Re: PRI line to CallManagerExpress - enabling caller ID?
Please send output of "debug isdn q931" with "term mon" for an incoming call.
Feb 13 15:27:19.011: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0B1C
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98383
Exclusive, Channel 3
Progress Ind i = 0x8583 - Origination address is non-ISDN
Called Party Number i = 0x81, '798'
Plan:ISDN, Type:Unknown
Feb 13 15:27:19.027: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8B1C
Feb 13 15:27:19.579: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x8B1C
Feb 13 15:27:19.635: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x8B1C
Feb 13 15:27:19.667: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x0B1C
Feb 13 15:27:19.667: %ISDN-6-CONNECT: Interface Serial0/0/0:2 is now connected to N/A N/A
Feb 13 15:27:25.667: %ISDN-6-CONNECT: Interface Serial0/0/0:2 is now connected to N/A N/A
Feb 13 15:27:27.779: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/0/0:2, changed state to up
Feb 13 15:27:28.123: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x0B1C
Cause i = 0x8090 - Normal call clearing
Progress Ind i = 0x8288 - In-band info or appropriate now available
Feb 13 15:27:28.123: %ISDN-6-DISCONNECT: Interface Serial0/0/0:2 disconnected from unknown , call lasted 8 seconds
Feb 13 15:27:28.123: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x4
Feb 13 15:27:28.135: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x8B1C
Feb 13 15:27:28.147: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0B1C
Like Dave also suggested, there is no caller number in the setup message, so you have to raise the issue with your telco.
Bronze
Okan,
Check with your SP that Caller ID is enabled.
Dave
145
