PRI Link status not established
I have a router E1 connection and the Telco are saying that they see the
PRI link status = PRI Link is not established.
On my router, I see the following
sh controllers e1
E1 0/0/0 is up.
  Applique type is Channelized E1 - balanced
  No alarms detected.
  alarm-trigger is not set
  Version info Firmware: 20100222, FPGA: 13, spm_count = 0
  Framing is NO-CRC4, Line Code is HDB3, Clock Source is Internal.
  Data in current interval (869 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     3 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     3 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 83 15 minute intervals):
     0 Line Code Violations, 22 Path Code Violations,
     175 Slip Secs, 1 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     175 Errored Secs, 0 Bursty Err Secs, 1 Severely Err Secs, 113 Unavail Secs
sh isdn status
Global ISDN Switchtype = primary-net5
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/0/0:15 interface
        dsl 0, interface ISDN Switchtype = primary-net5
        L2 Protocol = Q.921 0x0000  L3 Protocol(s) = CCM MANAGER 0x0003
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0xFFFF7FFF
    Number of L2 Discards = 0, L2 Session ID = 6
    Total Allocated ISDN CCBs = 0
Can anyone advice what could be the reason for this?
Thanks a lot in advance.
Kaushik
3 ACCEPTED SOLUTIONS
Blue
Layer 2 is TEI_ASSIGNED,             which indicates that the PRI does not exchange Layer 2 frames with your service provider PRI switch. Please make sure your service provider has given you correct link and is working.  also make sure you are using correct PRI modem and they are working properly.
regards
Ronak patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Green
Just to add to Ronaks post.
Your controller is showning internal clocking
And every second is a clock slipped second
Try changing your clocking to the line,
this is normal for ISDN/PRI
controller E1 0/0/0
description ***  Connected to ISDN PRI ***
pri-group timeslots 1-31 service mgcp
clock source line
You may need to find out from the TELCO whether they are using CRC4 or not
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Hall of Fame Super Gold
Re: PRI Link status not established
As told you above already, you should have clock line, not internal.
You also need network-clock-select 1 E1 0/0/0
Blue
regards
Ronak patel
Green
controller E1 0/0/0
clock source line
Alex.
Thanks Ronak and Alex
Actually the TELCO provided me with the following information,
Here are some items that you should configure on your side
SWITCH-TYPE - primary-net5
FRAMING TYPE - NON-CRC4
LINE CODE - HDB3
PCM -  a-law
CLOCK SOURCE – Internal
That is why i configured it like this.
I have asked them to confirm again.
My config is as follows:
controller E1 0/0/0
framing NO-CRC4
clock source internal
interface Serial0/0/0:15
no ip address
encapsulation hdlc
no logging event link-status
load-interval 30
isdn switch-type primary-net5
isdn overlap-receiving T302 2000
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn send-alerting
no cdp enable
Please let me know if the congfiguration on my side looks fine.
Thanks again
Thanks a lot all the E1 is now working fine after changing the clock to line.
Thank you for the nice rating and good luck!
458
