PRI / SRST incoming calls get dial tone
I am running CCM 4.1.3 with SRST. In fallback mode, when calling INTO the PRI, I get a secondary dial tone. If I then dial an extension, it will ring the phone. What am I missing to allow a normal call from the outside to reach the intended DID? Thanks
Re: PRI / SRST incoming calls get dial tone
Under your incoming dial peer, you need the command "direct-inward-dial".
Hope this helps. If so, please rate the post.
Brandon
Ball,
I have the following dial peer and problem persists:
dial-peer voice 7777 pots
preference 1
destination-pattern 9T
progress_ind setup enable 3
incoming called-number .
fax rate disable
direct-inward-dial
Bronze
Believe you need to indicate the port under here as well. IE if 1/0 is your PRI, you need the command
port 1/0:23
under this dial peer.
Hope this helps.
Jim
JIm,
Yes, I omited the port. I put the port in and also an num-exp statement, and incoming works. Thansk to all
If you do "debug voip dialpeer" and make an incoming call, do you see that the call hits the proper dial peer?
Brandon
520
