PRI Tie Line
I need to configure a PRI circuit that will be used for a "tie line" between two sites. The gateway will be h.323 and I have configured regular pri's before, just not for tie line.
Is their any special commands I will need to add for the tie line portion?
Thanks.
1 REPLY
Hall of Fame Super Gold
Re: PRI Tie Line
Are ou connecting two PBXs using two GWs ?
If so, yest the commands are the same as for a regular PRI.
Please rate post if it helps!
171
