PRI to CCM
Have a setup with a fractional T1 (Voice PRI) dialing into and out of a 2811 running CME.
Should we want to upgrade to CCM can i point the PRI on the 2811 to the CCM?  Or will i need a different kind of gateway?
John
Re: PRI to CCM
Yes, you can use it for CUCM, but since its fractional, then you need to use H323
java
if this helps, please rate
www.cisco.com/go/pdi
VIP Purple
Re: PRI to CCM
Hi John,
In addition to what Mr. Jaime has said[+5] , u can also refer the below links on Fractional E1 support on H.323 GW.
https://supportforums.cisco.com/message/1162035#1162035
https://supportforums.cisco.com/message/1083359#1083359
https://supportforums.cisco.com/message/3822472#3822472
regds,
aman
Hall of Fame Super Silver
PRI to CCM
SIP will work as well. In fact with either protocol you can share the PRI between CME and CUCM.
HTH,
Chris
142
