PRI Turnup ... International Not working
AT&T circuit in NYC ... getting this when dialing International. Local and LD are fine.
Jun 4 19:18:13.688: ISDN Se0/3/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0x8001
Cause i = 0x82FF - Interworking error; unspecified
Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
Any ideas?
Re: PRI Turnup ... International Not working
my guess is you need to specify a numbering plan and a plan type.
If this is an MGCP gateway, you can change those under the PRI gateway in the callmanager. If it's a CME or H.323 gateway, you can do an outgoing voice-translation profile to designate ISDN and National.
I suspect so ... but I'm not sure what values to change.
What system are you using and what type of gateway? I can get you a snippet or lead you in the right direction
Callmanager 5.1(3), MGCP 3825 w/ 12.4(19)
ISDN is NI2, two full PRIs (no NFAS)
Config is basic MGCP
well im facing the same problem , but with service number we use here in my country. we use 181 as directory service. route pattern 9.1xx discard digit predot. i can call 111 , 199 etc .. excpet the 181. i got error msg from the PSTN that the number not valid. and its routed to FXO port not ISDN. any idea?
You can't control the Information Element on an FXO port - it doesn't contain ISDN information. What message do you get when the call fails?
Are you running MGCP gateways or H.323?
taken from: http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml
Change Outbound Calls with a Plan and Type of Unknown to ISDN and National
voice translation-rule 1
rule 1 // // type unknown national plan unknown isdn
!--- Matches any number string with a plan and type of
!--- unknown. Also changes the type to national and the plan to isdn.
voice translation-profile isdn_map
translate called 1
!--- Invokes voice translation rule 1 in order to translate the called number.
dial-peer voice 1 pots
translation-profile outgoing isdn_map
!--- Invokes voice translation profile “isdn_map” for outgoing calls.
kearly01#test voice translation-rule 1 5551234 type unknown plan unknown
Matched with rule 1
Original number: 5551234 Translated number: 5551234
Original number type: unknown Translated number type: national
Original number plan: unknown Translated number plan: isdn
ah, okies, that previous post is h.323, that won't work.
in your mgcp gateway, there should be a setting for outbound calls. I'm not 100% on 5.x or 6.x, but in 4.x it defaulted to callmanager under plan type and numbering plan. You can set those to ISDN plan type and National numbering plan, reset the gateway and try it out.
Carriers are usually real picky about information elements on a PRI for international calls, it needs the plan type and numbering plan.
Yes, it's largely the same. I've tried a few combinations, but I'm largely guessing. I opened a TAC case and am awaiting contact.
TAC says based on the debug info the issue appears to be on the provider's side. Nothing to change with the config...
726
