Bronze
PRI up and Down Issues
Guys,
I'm really thinking this is a Telco issue but I'd like to get your thoughts on this.
On a 3945, I'm receiving a huge amount of RTMT alerts about a PRI going up and down a lot. The Show controller t1 ouutput show a lot of errors:
T1 0/0/0 is up.
  Applique type is Channelized T1
  Cablelength is long 0db
  Description: Circut ID XXXXXXXXXXX
  No alarms detected.
  alarm-trigger is not set
  Soaking time: 3, Clearance time: 10
  AIS State:Clear  LOS State:Clear  LOF State:Clear
  Version info FPGA Rev: 08121917, FPGA Type: PRK4
  Framing is ESF, Line Code is B8ZS, Clock Source is Line.
  CRC Threshold is 320. Reported from firmware  is 320.
  Data in current interval (433 seconds elapsed):
     0 Line Code Violations, 3714 Path Code Violations
     4 Slip Secs, 53 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     156 Errored Secs, 74 Bursty Err Secs, 4 Severely Err Secs, 49 Unavail Secs
  Total Data (last 24 hours)
     8467 Line Code Violations, 443834 Path Code Violations,
     2437 Slip Secs, 7480 Fr Loss Secs, 259 Line Err Secs, 54 Degraded Mins,
     19839 Errored Secs, 8507 Bursty Err Secs, 403 Severely Err Secs, 7576 Unavail Secs
T1 0/0/1 is down.
Anything else I need to look at?
Any help would be appreciated!
Gareth
Everyone's tags (3)
1 ACCEPTED SOLUTION
Blue
If path code violations keep increasing, contact your service  provider to check the line, because path code violations can be  caused by physical line problems. And you have 443834 Path Code Violations in last 24 hrs, you may want to check your service provider for the line.
See below troubleshooting guide
http://docwiki.cisco.com/wiki/Cisco_IOS_Voice_Troubleshooting_and_Monitoring_--_T1_or_E1_Interface_Troubleshooting#T1_or_E1_Interface_Troubleshooting
Ronak patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Blue
Ronak patel
Bronze
Re: PRI up and Down Issues
As we both thought, this did turn out to be a Telco issue. They had to reterminate a new pair for the T1.
Thank you for your reply.
Gareth
603
