01-09-2012 03:42 AM - edited 03-16-2019 08:53 AM
I have a PRI wich every day at differents times has a loop, when i check how many ports are available with "show voice call summary" i see all channel free for example, i wail a few seconds, repet the commands and almost all channel are occupated, I wait a second and are still all occupated, refresh and all free, etc.
Its looks like a loop because there is not a problem of number of channel ocupatted by users, any idea or commans to see if it is really a loop problem with this PRI??
Thanks.
01-09-2012 03:53 AM
You may have some phone that has call-forward to it's own PSTN number. That would cause the tromboning effect.
One way to find it is to take an ISDN trace to see the involved numbers.
01-10-2012 01:49 AM
Thanks, I will do tody a debug isdn q931 and check if could be a forward all or something else in the called numbers.
regards.
01-09-2012 05:46 AM
If you look at the underlying serial interface, that will tell you if there really is a loop or not.
GTG
01-10-2012 01:50 AM
Hi Gordon,
I dont understand at all what you mean with "underlying serial interface", please could you explain it better?
Thanks and regards!
01-10-2012 02:09 AM
PRI ISDN interfaces are made up of multiple layers in Cisco IOS.
At the top, you have, say, voice-port. This will usually be where you're handling voice traffic.
Below that you'll have a Controller. This speaks the ISDN protocol.
At the bottom, you'll have a serial interface. This does the work of sending/receiving the low-level data. PRI ISDN is based on a 2Mb/s serial connection (Or 1.5Mb/s)
Some snippets from an MGCP gateway of mine:
controller E1 0/1/0
pri-group timeslots 1-31 service mgcp
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
voice-port 0/1/0:15
echo-cancel coverage 64
cptone GB
(Just bear in mind, that when a gateway is configured in MGCP mode, most of the grunt work is actually handled by CUCM not the IOS gateway)
BRI is much simplier in Cisco IOS: Just an interface of type "BRI" & a Voice-Port
So when I say look at the underlying serial interface, if you do a "sh int ser0/1/0:15" (For my gateway, at least) you'll get the traditional IOS Serial data dump:
Serial0/1/0:15 is up, line protocol is up (spoofing)
Hardware is DSX1
MTU 1500 bytes, BW 64 Kbit/sec, DLY 20000 usec,
Encapsulation HDLC, crc 16, loopback not set
Keepalive set (10 sec)
Last input 00:00:07, output 00:00:07, output hang never
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 48 kilobits/sec
2119962 packets input, 8480583 bytes, 0 no buffer
Received 0 broadcasts, 111 runts, 0 giants, 0 throttles
1487 input errors, 1487 CRC, 0 frame, 0 overrun, 0 ignored, 16 abort
2121385 packets output, 8486472 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
1 carrier transitions
And it's near the top that, if there's a loopback detected, you see it mentioned.
GTG
01-10-2012 04:01 AM
Hi Gordon,
First af all, thanks for your reply, this is my interface serial 0/0/0:15
ILL05254#sh int serial 0/0/0:15
Serial0/0/0:15 is up, line protocol is up (spoofing)
Hardware is DSX1
Last input 00:00:00, output 00:00:00, output hang never
1008190 packets input, 12270627 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
39 runts, 8 giants, 0 throttles
714 input errors, 706 CRC, 0 frame, 0 overrun, 0 ignored, 1 abort
1079123 packets output, 11493562 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
21 carrier transitions
And the configuration of my MGCP Gw is:
controller E1 0/0/0
interface Serial0/0/0:15
no ip address
encapsulation hdlc
no cdp enable
voice-port 0/0/0:15
cptone ES
bearer-cap Speech
busyout monitor GigabitEthernet0/0
It seems like yours, just change "busyout monitor ..." and cptone , but the rest is simillar, but making a debug i can see even all the time something like this which i dont know what does it means:
Codeset 4 IE 0x31 i = 0x81
Jan 10 11:29:36.655: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0xB105
Channel ID i = 0xA98391
Exclusive, Channel 17
Jan 10 11:29:38.171: ISDN Se0/0/0:15 Q931: TX -> PROGRESS pd = 8 callref = 0xB105
Facility i = 0x9FAA06800100820100A1080201010201018400
Progress Ind i = 0x8181 - Call not end-to-end ISDN, may have in-band info
Jan 10 11:29:38.219: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8 callref = 0xB131
Jan 10 11:29:38.219: ISDN Se0/0/0:15 Q931: TX -> PROGRESS pd = 8 callref = 0xB104
Jan 10 11:29:38.267: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8 callref = 0xB130
Jan 10 11:29:38.267: ISDN Se0/0/0:15 Q931: TX -> PROGRESS pd = 8 callref = 0xB103
Jan 10 11:29:38.315: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8 callref = 0xB12F
Jan 10 11:29:38.315: ISDN Se0/0/0:15 Q931: TX -> PROGRESS pd = 8 callref = 0xB102
Jan 10 11:29:38.363: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8 callref = 0xB12E
Jan 10 11:29:38.367: ISDN Se0/0/0:15 Q931: TX -> PROGRESS pd = 8 callref = 0xB101
Jan 10 11:29:38.415: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8 callref = 0xB12D
Jan 10 11:29:38.419: ISDN Se0/0/0:15 Q931: TX -> PROGRESS pd = 8 callref = 0xB100
Jan 10 11:29:38.463: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8 callref = 0xB12C
Jan 10 11:29:38.467: ISDN Se0/0/0:15 Q931: TX -> PROGRESS pd = 8 callref = 0xB0FF
Jan 10 11:29:38.511: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8 callref = 0xB12B
Jan 10 11:29:38.515: ISDN Se0/0/0:15 Q931: TX -> PROGRESS pd = 8 callref = 0xB0FE
Jan 10 11:29:38.559: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8 callref = 0xB12A
Progress Ind i = 0x8181 - Call not end-to-end ISDN, may have in-band info Codeset 4 IE 0x31 i = 0x81
And triying to make a call with the CSS of that Gw to a mobile, every 5 test, 4 fails.
Any idea? seems configuration is ok, but traces are stranges.
Thanks in advance.
01-10-2012 04:29 AM
What does this PRI link connect to.
Is it the public PSTN or a private PBX etc ?
You have selected ISDN witch-type prim-qsig
Are you sure that in Spain you should be using prim-net5
Alex
01-10-2012 06:06 AM
Hi Acampbell,
Thanks for your reply, here you are your answers in black:
What does this PRI link connect to. I dont know, phisically is not in my site
Is it the public PSTN or a private PBX etc ? public PSTN
Are you sure that in Spain you should be using prim-net5 , yes is net5
We have 10 Gw more and this is the only wich fails.
Thanks.
01-10-2012 06:35 AM
You should avoid MGCP.
With H.323 or SIP, you would have a more robust solution, more features, and easier troubleshooting.
01-10-2012 06:47 AM
Hi Paolo,
H.323 is worst because all is managed by the own gateway, not CUCM, and It could not be a solution because all gateways are in MGCP.
regards.
01-10-2012 06:57 AM
It is actually better because the gateway manages things better, as you can see by the weird problem you're facing..
You can have a mix of H.323 and MGCP GWs if you want.
01-10-2012 07:06 AM
If you are sure that it should be PRIM-NET5 then make the following changes
shut
no ip address
encapsulation hdlc
no isdn switch-type primary-qsig
isdn switch-type primary-net5
no cdp enable
no shut
You will also need to correct the switch type on the MGCP gateway end point on CUCM
to PRI EURO
Save and reset.
Alex
01-10-2012 07:09 AM
acampbell wrote:
You will also need to correct the switch type on the MGCP gateway end point on CUCMto PRI EURO
Save and reset.
Actually, you only need to do that in CCMAdmin. It will push the new config down to the gateway automatically (after a suitable "Save/Apply Config"). That's the reason for MGCP ;-)
GTG
01-10-2012 07:06 AM
Hmm, I'd probably disagree. MGCP does have limitations (Unable to filter on calling DN, unable to see interface activity on the gateway) but on the whole it's fine. And it certainly doesn't prevent you fault finding ISDN problems, as all the debug isdn commands still work.
Anyway, getting back to the original poster's problem....
As you have plently other gateways with the same config working, my gut feel is that it could be a fault with the PSTN switch at the other end. Log a call with your PSTN provider and see what they say. Nine times out of ten, when it's a wierd problem list this, it's the PSTN's fault.
GTG
