Prime Collab Deployment - Unrestricted to Restricted
Anyone have any experience using Prime Collaboration Deployment to migrate a Unity Connection (or CUCM for that matter) server from an Unrestricted release to a Restricted version? Not necessarily doing an upgrade, but a full migration to a new host from an old MCS (going from version 7.1(5) to 10.0 in the process). So I'm wondering if since it's technically a new install and the configuration is being migrated, if it might work using PCD.
No, it won't work, there is
No, it won't work, there is no method, besides BAT, to go from un-restricted to restricted.
PCD should work the other way around, as would a regular upgrade, from restricted to un-restricted.
java
if this helps, please rate
www.cisco.com/go/pdi
That's too bad..Not even the
That's too bad..
Not even the most recent release of PCD will do this?
I was given the impression at Cisco Live that it would work..
What is the reasoning behind this not working or being a viable option?
No, it won't work, PCD
No, it won't work, PCD follows the same rules we already had in place regarding un-restricted to restricted migration.
If you want further explanation as to technical reasons, reach your SE or AM for that matter.
java
Jamie, well don't that beat
Jamie, well don't that beat all and its actually a shame.. Especially seeing how there is an impression that PCD would be able to do it all per se'.
As far as restrictions are concerned, I'm very familiar with export and ITAR requirements; however data that makes up a dial-plan, phones, etc. is not considered to be export restricted unless certain encryption types are being used.
Before contacting them, I'd prefer to read the technical reasons myself.. Is this published anywhere?
No, it's not published
No, it's not published anywhere.
java
Okay.. Well that's too bad
Okay.. Well that's too bad also.. We had a very hard time trying to find restrictions on PCD on CCO especially around this particular function.. It wasn't until we tried a migration that we encountered some issues with ISO's not showing up as being valid.
What is the confidence level that BAT would actually work... ?
BAT is the raw data from the
BAT is the raw data from the DB in CSV, nothing to do with restricted or unrestricted versions.
java
So..We've got new OVA's
So..
We've got new OVA's deployed and Bootable restricted ISO's..
Even if we are migrating to brand new VM's? Not in-place upgrade.. In-Place upgrade I can understand why one couldn't upgrade the existing VM
PCD Upgrade taskRestr to
PCD Upgrade task
  • Restr to Restr YES
  • Unrestr to Unrestr YES
  • Others NO
PCD Migration task
  • Restr to Unrestr YES
  • Unrestr to Restr NO
java
VIP Purple
[+5] to Jaime for sharing the
[+5] to Jaime for sharing the info.
Jamie.. Good info..
Jamie.. Good info..
Unfortunately Cisco TAC doesn't even know about this.. They had to check and it wasn't just one TAC Engineer that needed to do so..
So I was told that they are opening up product documentation bugs so that this is referenced in full.
Well, it is not in the docs,
Well, it is not in the docs, I also had to reach the PM to find this, I just asked him if they could get this into the PCD documentation and referenced your case. Hopefully they'll add this to the new PCD docs.
java
237
