Prime Collaboration Provisioning with 2008R2
Is anybody using Prime Collaboration Provisioning with a 2008R2 AD and doing LDAP authentication?  Trying to set it up here, and getting an error of:
Error Message:
Login to the LDAP server failed. Please check the  credentials. ldap://10.4.0.X:389
The documentation mentions AD 2000/2003/2008 as supported, Active Directory guys say that 2008R2 had quite a few changes to AD functionality.  Can anybody from Cisco speak to whether AD 2008R2 or 2012 will be supported in CPCP 10.0?
We also have an ACS server we can use, just trying to avoid having to create 30-40 accounts for remote field guys in our ACS if they already have LDAP accounts that work for all their other authentication.
1 REPLY
Roadmap questions, or questions on products which have not been released, cannot be answered here.
I recommend you ask that here:
https://communities.cisco.com/community/partner/collaboration?view=overview
Or reach your SE/AM.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
126
