06-13-2014 06:59 AM - edited 03-16-2019 11:06 PM
Hi all
recently we migrated to CUCM 10.0 using the PCD.
The migration is ok, but i can´t login to the Prime License manager co-resident in the CUCM.
I try with the same credentials of the CUCM, but it say error user/password
Thanks a lot
Guillermo
06-13-2014 07:35 AM
What do you get if you issue this command via CLI
license management list users
06-13-2014 07:38 AM
jaime,
I obtain this
admin:license management list users
App user: ccmadministrator
Remember it is co-resident, then I connect to the cucm CLI.
06-13-2014 07:39 AM
Is that the user you're trying to use??
06-13-2014 07:45 AM
Yes, and try using the same password of the CUCM.
12-16-2015 01:50 AM
Not sure if you ever resolved this but I was just facing a very similar issue, unable to log into PLM with App Admin username and password, then I remembered that I had changed the App Admin password, so tried the old password and I was then able to log in.
It appears that the PLM user isnt linked to the UCM App Admin account, looks like its just a copy when the server is first created.
Richard
