Prime License Mnager co-resident I can´t Login
Hi all
recently we migrated to CUCM 10.0 using the PCD.
The migration is ok, but i can´t login to the Prime License manager co-resident in the CUCM.
I try with the same credentials of the CUCM, but it say error user/password
Thanks a lot
Guillermo
What do you get if you issue
What do you get if you issue this command via CLI
license management list users
java
if this helps, please rate
www.cisco.com/go/pdi
jaime,I obtain thisadmin
jaime,
I obtain this
admin:license management list users
App user: ccmadministrator
Remember it is co-resident, then I connect to the cucm CLI.
Is that the user you're
Is that the user you're trying to use??
java
Yes, and try using the same
Yes, and try using the same password of the CUCM.
Not sure if you ever resolved
Not sure if you ever resolved this but I was just facing a very similar issue, unable to log into PLM with App Admin username and password, then I remembered that I had changed the App Admin password, so tried the old password and I was then able to log in.
It appears that the PLM user isnt linked to the UCM App Admin account, looks like its just a copy when the server is first created.
Richard
881
